Help! Question about Head Gaskets?
Old Feb 18, 2006 | 08:41 PM
Bradazz's Avatar
Default Help! Question about Head Gaskets?
I was just reading through some posts about head gaskets and I have a couple of questions. I used the multi layer steel head gaskets (part #12589226) when I installed the heads. Did I use the right ones for my application? I really need to know before I put my engine back together. If I used the wrong ones then which ones should I use?
Old Feb 18, 2006 | 09:31 PM
Yelo's Avatar
AFAIK it's the right gasket part #.....But I've never used the MLS, All I use are FelPro
Old Feb 18, 2006 | 10:12 PM
moregrip's Avatar
what a rush!
what does AFAIK stand for again?
Old Feb 18, 2006 | 10:20 PM
Yelo's Avatar
As Far As I Know.......
Old Feb 18, 2006 | 11:00 PM
Bradazz's Avatar
I just want to make sure I am using the best gasket for my application, If there is something else that would be better to use then I need to know what that is. I would rather change gaskets now instead of finding out later that I should have used something else.
Old Feb 18, 2006 | 11:09 PM
quicksilverado's Avatar
MLS gaskets are used on alot of f.i. motors They will hold up just fine.
Old Feb 18, 2006 | 11:10 PM
Bradazz's Avatar
Sounds good. Thanks Alot.
Old Feb 18, 2006 | 11:20 PM
I used them. They are pretty good gaskets.
Old Feb 18, 2006 | 11:55 PM
moregrip's Avatar
what a rush!
I will be using GM MLS gaskets on my setup.
If you are comfortable with the quench the stock gasket provides I see no reason to get anything else.
Old Feb 20, 2006 | 11:31 AM
Bradazz's Avatar
The gaskets that I used are for 05-06 Silverado's w/ 5.3L B Code Engine, Does that change anything since I have a 2000 Silverado?
thunder550
Oct 8, 2015 04:53 PM
dantheman1540
Jul 29, 2015 04:45 PM
BIGD4504
Jul 28, 2015 11:46 AM
bbowerman
Jul 26, 2015 10:57 PM
