HELP Powerbond pully
Old Oct 16, 2011 | 11:17 AM
gtx99sierra's Avatar
Default HELP Powerbond pulley
i have a 99 4.8 I'm trying to install a powerbond pulley it says 6.0 lq4 on the box but it should still fit right??? I'm having trouble installing it is there any tip and tricks you guys can help me out with is there a certin pulley installer i have to use thanks in advance
Old Oct 16, 2011 | 12:14 PM
Mangled03gmc's Avatar
Baltimore Whore
It should be the same for the 4.8-6.0 engines.. You need to take that pulley and stick it in the oven for a little bit to get it hot, or stick it into a pot of hot hot water, so the opening expands, then you need to hurry the hell up and get it started onto the crank.. Do you have the longer crank bolt, to help it pull it on?? The stock one will work, but you MUST make sure you have that pulley started well onto the crank or you could risk pulling threads on the crank..
Old Oct 16, 2011 | 01:38 PM
fastrt's Avatar
11 Second Truck Club
powerbond pulleys suck! U need a pulley installer from dirt track racer.
Old Oct 16, 2011 | 05:03 PM
I'm useing stock bolt and were can I get the correct installer
Old Oct 17, 2011 | 12:56 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You need this. Scoggin Dickey Parts Center SD6628 - LS Balancer Install Tool | SDParts - 1-800-456-0211
Old Oct 17, 2011 | 11:21 AM
budhayes3's Avatar
PT's Slowest Truck
According to GM, the stock bolt is a one time TTY bolt (although many have reused theirs before). Considering that a new bolt is less than 10 bux from the dealership though, it's worth it for some cheap insurance IMO.
Old Oct 20, 2011 | 01:31 PM
What size belt do I use for this the pulley is on
Old Oct 20, 2011 | 02:37 PM
Beau@SDPC's Avatar
Trucks Sponsor
See sig!
In stock, ready to ship. Purchase Online for $59.70 shipped!!!
Old Oct 20, 2011 | 04:10 PM
Beau@SDPC's Avatar
Trucks Sponsor
PM sent!
Old Oct 20, 2011 | 04:19 PM
Beau@SDPC's Avatar
Trucks Sponsor
$4.85 through us, $21.95 for our reuseable....VERY CHEAP Insurance indeed!!!
