help! no start after intake swap
Old Oct 25, 2006 | 10:06 PM
WhiteChevy3's Avatar
Default help! no start after intake swap
well tonight i swaped out my K&n cone back for the stock air box(until i make a new sealed air box), after i put it all back together when i go to start it , it busts off for a second and then dies, it was running fine today until this , i have switched back to the cone filter, but still does the same thing, could the MAF gone bad or something??? i noticed a residue on the maf and cleaned it off with a q-tip and some eletronic cleaner, that didnt seem to help, i have no idea whats goin on please help
Old Oct 25, 2006 | 10:11 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Did you damage the little electrodes on the MAF?
Old Oct 25, 2006 | 10:14 PM
tyrsmkr's Avatar
Check for air leaks after the maf. To me it sounds like you are getting air into the engine that the maf isn't seeing. The exact same thing happened to me when I ripped the intake elbow on my camaro.
Unplug the maf and try to start it a couple times.
Old Oct 25, 2006 | 10:15 PM
a while back when i was messin with the intake i bent in one of the electrodes, . but it still ran fine, mabey that messed it up, but why now? and not when i did it first?
Old Oct 25, 2006 | 10:18 PM
blake2kz71's Avatar
did you disconnect your battery before you swapped back?? I have done this before and it was a security issue (the truck would stay running for about 1 or 2 seconds then die) Try disconnecting your battery and leave it disconnected for a few minutes.
Old Oct 25, 2006 | 10:50 PM
tried the disconecting the battery still no luck
Old Oct 25, 2006 | 10:53 PM
tyrsmkr's Avatar
did you try to start it with the maf unplugged?
Old Oct 25, 2006 | 10:56 PM
yea it just revs up high, then i shut it off
Old Oct 25, 2006 | 10:58 PM
tyrsmkr's Avatar
Wow thats a new one. I think somebody put the heebie jeebies on your truck man.
Ill think it over, good luck.
Old Oct 25, 2006 | 10:59 PM
help appericated
