HELP my turck wont start after pcm install!!!
Old Mar 10, 2005 | 07:53 PM
02chevyracing's Avatar
14 Second Truck Club
Default HELP my turck wont start after pcm install!!!
I just installed a tune from TX speed and my truck wont work Ive tried the start wait 5 sec turn off 5min did that four times and it still wont start what next???
Old Mar 10, 2005 | 07:54 PM
2toneblown's Avatar
sounds like security issues
Old Mar 10, 2005 | 07:56 PM
99Silver6.0's Avatar
BCM isnt getting the right R-code. Might want to try the security re-learn again if you havent already. Now, when you did the procedure, were you just waiting five minutes? Or did you wait for the security light to stop flashing?
Old Mar 10, 2005 | 08:03 PM
is it leave it on and wait until to the securty light blinks? or try to start it and wait 5 sec turn the key off?
Old Mar 10, 2005 | 08:30 PM
Zick's Avatar
Try this;
Here this will probably help better;
LINKY
Old Mar 10, 2005 | 08:47 PM
He posted a good link. Check that procedure. But when the time comes, leave they key ON till the light goes out.
Old Mar 10, 2005 | 10:22 PM
Sleepy53's Avatar
Originally Posted by Zick
Try this;
LINKY
That should fix your problem. Hope it works out for you.
Old Mar 10, 2005 | 10:31 PM
i gave up tonight ill let you guys know tommarrow thanks Where is rockwall?
Old Mar 10, 2005 | 10:40 PM
CAMMIN03''s Avatar
Banned
Try to crank it.... Leave the key in the on position for no less than 11 minutes..
Then turn the key to the off position for no less than 30 secs..
Repeat this 3 more time... it should start on the 4th or the 5th...
Do not do the times anyless than the stated times... over that is ok though...
Old Mar 10, 2005 | 11:01 PM
Sleepy53's Avatar
It's about 20 miles east of Dallas on I30.
