Help me figure out what 6.0 I got
Old Aug 27, 2008 | 10:00 PM
JakeBrakeIH's Avatar
Originally Posted by hirdlej
On the front engine pad on the pass side you'll see a number that looks something like A145 the letter (A in this case) is the month of the year, the 2nd set of numbers is the day of the month (14th day in this case) and the last number is the year (5 for '05 in this case). Get me those numbers and I will decipher your block for you
awesome man thanks for all ur help...my friend is going home this weekend from college so Ill try and have him look at the numbers so I can figure out what the deal is...I think I have a feeling it has iron heads on it but w/e...for $300 bucks I cant complain...
Old Aug 27, 2008 | 10:32 PM
InchUp's Avatar
Ahh ha, that's it! I knew you'd see this eventually. Like I said, I'd need to be standing over my motor to see the characters in person in order for the lesson to come back and flood into my memory.
Thanks hirdlej for helping out on my senior moment.
Old Aug 27, 2008 | 10:37 PM
GMCtrk's Avatar
Interesting. But this can't differentiate between an LQ9 and LQ4 though correct?
Old Aug 27, 2008 | 10:41 PM
hirdlej's Avatar
no it won't differentiate lq4 vs lq9. But it will confirm to the buyer what the seller claims for engine year
Old Aug 27, 2008 | 10:42 PM
GMCtrk's Avatar
I'm very interested to find out what I see when I pull the heads on my 6.0
Mine is supposedly an 02 LQ9...
What is the "front engine pad"?
Old Aug 27, 2008 | 10:58 PM
hirdlej's Avatar
It's the flat area right if you were looking down at your motor right between you and the cyl head. Sometimes the paint is rusty here and you have to swab some motor oil over the letters and numbers so you can read them.
Old Aug 27, 2008 | 10:59 PM
hirdlej's Avatar
Quickest way to tell if you have a LQ4 or LQ9 is to pull a spark plug and take a straight blade screwdriver and VERY GENTLY touch it against the cyl wall of the block and gently push down and draig it across the top of the piston. If you feel it sink down it's an LQ4, if it stays flat and smooth it's a LQ9
Old Aug 27, 2008 | 11:01 PM
GMCtrk's Avatar
Are you talking about where they have 6.0L printed on the block?
Old Aug 27, 2008 | 11:43 PM
hirdlej's Avatar
pass side
Old Aug 28, 2008 | 09:19 PM
InchUp's Avatar
Block deck, right in front of the cylinder directly behind the water pump in this picture. It's the flat surface of block/deck surface in front of the passenger side head, ON THE BLOCK.
