Help me figure out my compression ratio...
Old Sep 24, 2003 | 07:54 PM
Default Help me figure out my compression ratio...
ok i got my pistons in for the 6.0 today...im hopin to get low 10's on the compression...the piston size is 4.030...they are dished...and my heads are gonna be about 72cc or so...what else do u need to know to figure out the compression? thanks!!
Old Sep 24, 2003 | 08:03 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Help me figure out my compression ratio...
What is the dish size? They're diamonds right? If so they are probably .010" above the deck?(What is the compression height on the box) Head gasket thickness plays a role but, a good idea can be figured out using the stock specs.
Get that stuff and I'll let you know.
370ci right.
Old Sep 24, 2003 | 08:24 PM
YES THEY ARE DIAMONDS AND IT IS A 370...the only thing i could find on the spec sheet that u listed is the compression height...it is 1.315 if that helps
Old Sep 24, 2003 | 09:01 PM
XLR8NSS's Avatar
Adkoonerstrator
Wellllllll, that helps a little bit but, depending on the dish size it would be real hard to guess.
Need to have dish cc.
Old Sep 24, 2003 | 09:13 PM
just assume .010 above deck or whatever u said...b/c i cant find it anywhere
Old Sep 24, 2003 | 09:53 PM
XLR8NSS's Avatar
Adkoonerstrator
Ok I'll go ahead and figure your compression ratio using a stock gasket, 1.315 compression height( = .011 above the block deck), 72cc heads, and dishes from 6-13cc.
<font class="small">Code:</font><hr /><pre>
Dish size Compression ratio
6 9.65:1
7 9.55:1
8 9.45:1
9 9.36:1
10 9.27:1
11 9.18:1
12 9.09:1
13 9.00:1
</pre><hr />
If you want in the low 10:1 area you'll need to go with a smaller combustion chamber on the head. Probably somewhere in the low to mid 60 cc range
Old Sep 24, 2003 | 10:16 PM
thanks for the help man...ill probaly go with the new patriot ls6 heads which are 64cc
03sierraslt
14
Oct 9, 2015 05:53 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
