Help with leaking valve seals during compression test!
Old 08-25-2010, 02:31 AM
brandon_6667's Avatar
I've decided to pull the heads, get them all checked out and serviced. That way I can look at the rest of the motor and make sure everything looks ok. alot of guys are telling me the leakdown is normal but i want to know for sure that the heads are 100% good to go
Old 08-25-2010, 12:43 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Old 08-26-2010, 12:02 PM
how about the head bolts? I know you should not reuse them so Im looking at buying a new set of stock head bolts. but dont you need a special Torque wrench to install them because you measure torque angle and not FT/LBS ?? IIRC I read that if you buy the $100+ ARP head bolts you can use just FT/LBS but the stockers require a different procedure.
Old 08-26-2010, 12:27 PM
I have a gauge for that
Atomic's Avatar
intial torque ti 22 ft lbs, then just mark it with a marker and turn the desired degrees
Old 08-26-2010, 12:31 PM
Seems awfully loose, but i guess it torques down pretty good when you turn it to the correct angle.
Old 08-26-2010, 02:15 PM
Atomic's Avatar
haha, give it a try and youll see.
Goat's ss
01-03-2016 06:28 PM
JFortner5
08-24-2015 10:32 PM
DrX
08-19-2015 04:45 PM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: Help with leaking valve seals during compression test!
