Help identifying a block
Old Dec 26, 2010 | 03:37 AM
87chebby's Avatar
Registered User
Default Help identifying a block
I have a stock 87 Silverado, My brother purchased me a motor and he says its a 400 but how can I be sure?
I would like to know which block it is to keep records and which intake to purchase(didnt come with one).
Also my truck is currently tbi, what all will I need to do to convert to carburated with out any problems?
Old Dec 26, 2010 | 09:05 AM
Bluchevypick's Avatar
Take the serial number off of the back of it and type it into google. You should be able to come up with something, or you could take it to a local machine shop and they can verify it.
Old Dec 26, 2010 | 12:13 PM
1Bear's Avatar
While you can look at the freeze plugs to get an idea, don’t get hung up on trying to determine whether or not a particular block has three or only two, as the blocks were available in both configurations. If the block doesn’t have the heads installed, it will have at least a 4.125” bore, while a 350 or 327 would have had at least a 4.00” that may have been taken out to a 4.060” if it was over-bored a good amount, but it’s still a good way’s from the 4.125” minimum bore size of the 400. If the balancer is still installed, it will have a scalloped out area on the outer edge of it, but if someone used the 400 crank and balancer in a 350 block to build a 383 this is not a 100% identifier. Here is a decent site to look for the casting numbers: http://www.chevymania.com/
Old Dec 26, 2010 | 12:23 PM
87chebby's Avatar
Registered User
It has 3 freeze plugs
Block number is 330817
What do you mean a scalloped out area around the edge?
Old Dec 26, 2010 | 12:27 PM
MikeGyver's Avatar
If the heads are off, the 400 has steam ports between the cyclinders.
Old Dec 26, 2010 | 12:35 PM
1Bear's Avatar
Casting number 330817 is a small block 400.
Notice the cut out area.
Old Dec 26, 2010 | 12:43 PM
viciousknid's Avatar
Where's the Beef?
Best way to tell right there. Just look for small holes between the cylinders if the heads are off.
Old Dec 26, 2010 | 12:50 PM
Mangled03gmc's Avatar
Baltimore Whore
I know this for a fact..There could be 2 or 3 freeze plugs on the block, depending on what year it is.. All the 400 cranks had a small dowel pin in them, along with the bigger notched balancer.. 400's have a bulge in the block around the cylinder bores, you can feel them..
Also( found this)
330817 1970-80 400 150-180 2 bolt
3951509 1970-80 400 only 150-265 2/4 bolt
Old Dec 26, 2010 | 12:54 PM
Where's the Beef?
I'm guessing you didn't put that into Google as suggested. Google is your friend. Use it wisely.
http://www.nastyz28.com/sbchevy/sblock.php
Old Dec 26, 2010 | 01:46 PM
JoeGibbSilverado's Avatar
like mentioned, you cant go by the amount of freeze plugs. best way is pull the head and look for the steam holes, if by chance they were filled, (my dad has his filled) the motor will be externally balanced
