Help with head swap
Old Jul 12, 2012 | 08:13 PM
banjoman's Avatar
Default Help with head swap
I have an 05 silverado with 5.3. Developed the dreaded cracked head (castech). I've found a set of 243 heads to swap out. Truck already has a cold air intake. Diablo predator and cat back exhaust.
1) do I need to mill the heads to get proper compression ratio?
2) thinking of a cam swap to take advantage of the better heads while it's apart. Recomendations? Nothing crazy as I use it mostly for pulling my boat or atv trailer.
3) which short tube headers? Don't want the expense of going to lt's.
Thanks for your input
Old Jul 13, 2012 | 05:52 PM
batboy's Avatar
11 Second Club
Yeah, you'll need to mill the heads about .020" to get the CR to equal the 5.3 heads. Comp Cams 212/218 low lift with LS6 springs seems to be a good truck combo.
Old Jul 13, 2012 | 10:41 PM
banjoman's Avatar
Thanks for your reply. WOW 177 veiws and only 1 response....HMMMM
Old Jul 13, 2012 | 10:54 PM
AndysC3's Avatar
+1. I would mill the heads about .30 for the compression, dont forget to check the lifter preload when you mill the heads.
Old Jul 13, 2012 | 10:58 PM
darnie's Avatar
x 2 i milled my heads .12 bumped up the compression alittle but bairly cleared 7.4 rods id deff check em before you bolt them down
Old Jul 13, 2012 | 11:14 PM
AndysC3's Avatar
My heads are milled .025 and I needed a 7.375" push rod for proper preload.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
