Help with fuel pump
Old May 15, 2016 | 12:18 PM
chittychevy's Avatar
Default Help with fuel pump
04 silverado 4.8 fuel pump went out I don't really need the whole assembly just the pump so I need advice on where to get one and if I could get like a direct fit performance one
Right now the truck is tuned and stalled with 4.10s but probably have a cam and more boltons in its future
Old May 15, 2016 | 05:40 PM
Wolftrk99's Avatar
Walbro make a drop in "performance"unit... That comes assembled and ready to drop in.... Alot of times its the wiring in the module that goes out... If not wiring going to the pump....
Old May 15, 2016 | 06:08 PM
Yeah been searching I'm towing it home tomorrow so I can really see what's going on but looks like if it the pump I'll go with the walboro
Also if anyone knows just had a tune done a month ago if the pump was weak do I need to get a retune for the new pump or doesn't it matter
Old May 15, 2016 | 06:45 PM
Wolftrk99's Avatar
So long as youre regulator is good shouldnt be a problem.... Have you tried the tried and true method of beating on the fuel tank while someone is cranking it?? Could save you a tow bill....
Old May 15, 2016 | 07:37 PM
I literally just did that started up made it home!!! But won't restart I guess that's still leaning towards a pump I'll pull the bed off and check the electric right at the pump tomorrow
Old May 15, 2016 | 08:10 PM
Wolftrk99's Avatar
Probably just got the kast little bit out of the pump before it finally gave out!!!
chevy2inreno
Jun 22, 2016 02:48 PM
stylinfosho
Mar 8, 2016 10:24 PM
smoketrail
Mar 6, 2016 11:03 PM
brent1976
Mar 6, 2016 07:08 AM
Chevyssr1997
Mar 2, 2016 11:46 AM
