Help! Fuel Filter Connection Leaking!
Old Dec 27, 2005 | 05:30 PM
14 Second Truck Club
Default Help! Fuel Filter Connection Leaking!
I was changing my oil today and I was fixing to change my fuel filter when I saw that it was dripping fuel out of where the fuel line meets the fuel filter on the right side. The connection was tight, so I changed the fuel filter. I checked to make sure the small black rubber O-rings where at the ends and put the new one on. Cranked the truck up and it was still slowly dripping. Can I put something around it to make it stop or something? Please give some input! Thanks.
Old Dec 29, 2005 | 08:46 PM
white lightning SS's Avatar
clean the ends up good w/ a wire brush and make sure these are GM o-rings for that purpose because they will still leak. I have had this problem at work many times. some times the threads become too dirty to actually tighten far enough in the filter.
Old Dec 31, 2005 | 12:16 AM
I'll try that! Thanks a lot for the info! Do you think I should just replace the little O-rings with some newer ones?
Old Dec 31, 2005 | 12:45 AM
04BlackGmc's Avatar
10 Second Club
wierd ive only done a few one the NBS but havent had this issue, just like he said make sure everything is clean.
thunder550
Oct 8, 2015 04:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MWRitter
Jul 27, 2015 09:41 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
