Help with cam
I know, I know, there's a cam sticky. The problem is nobody listens to me because it's not my thread. SO........ How does a 220/224 cam sound?
Or is that too big for a 5.3L? Some idling clips would be nice too, and I don't care that much about the idle/lope or driveability because I only drive a little over 100 miles a week.
I actually like that cam. That would be about one of the only other cams besides the one that I am currently using that I would consider. I would have a noticable lope to it, but not terribly aggressive. You would definitely need about a 3000 stall converter depending on what gear you are using. If this one is on a 114 LSA, it wouldn't be too difficult to get to idle correctly, and would produce some noticable gains. I don't know anyone using this cam though. I have seen guys using slightly larger cams than this though in the 5.3 with no troubles. It would sacrifice a little low end but that is what you would want the higher stall converter for. It should produce nice mid to high range numbers though. I say go for it.
Originally Posted by 2000 SILVERADO
Do you have a converter for the cam, or was that with the stock stall?
the numbers where on a stock stall track times coming friday hopefully with street tires
ill let you know, haha. ive got the 220/224 Comp on the way. getting a tune at the same time. i may not have a chance to put it in this weekend, hopefully next weekend itll be in there. mine's a 5.3, 3.42 gear and a stock converter (for now). CHIP
BTW, sick car you have there.
