Help with cam
Old Jul 26, 2005 | 01:29 PM
2000 SILVERADO's Avatar
Talking Help with cam
I know, I know, there's a cam sticky. The problem is nobody listens to me because it's not my thread. SO........ How does a 220/224 cam sound? Or is that too big for a 5.3L? Some idling clips would be nice too, and I don't care that much about the idle/lope or driveability because I only drive a little over 100 miles a week.
Old Jul 26, 2005 | 02:45 PM
white1's Avatar
How does it sound for use, or how does it actually sound? As for use, it all depends on what you're wanting, and your specific application.
Old Jul 26, 2005 | 03:12 PM
BLACKND's Avatar
I actually like that cam. That would be about one of the only other cams besides the one that I am currently using that I would consider. I would have a noticable lope to it, but not terribly aggressive. You would definitely need about a 3000 stall converter depending on what gear you are using. If this one is on a 114 LSA, it wouldn't be too difficult to get to idle correctly, and would produce some noticable gains. I don't know anyone using this cam though. I have seen guys using slightly larger cams than this though in the 5.3 with no troubles. It would sacrifice a little low end but that is what you would want the higher stall converter for. It should produce nice mid to high range numbers though. I say go for it.
Old Jul 26, 2005 | 07:08 PM
Yep, already planning on a 3000 stall, just trying to find a BIG cam but not too big.
Old Jul 26, 2005 | 07:10 PM
Z284thgen's Avatar
11 Second Club
see sig for mods
Old Jul 26, 2005 | 07:13 PM
Originally Posted by Z284thgen
see sig for mods
Do you have a converter for the cam, or was that with the stock stall?
Old Jul 26, 2005 | 07:20 PM
Z284thgen's Avatar
11 Second Club
i have the pye3600 sitting in the garage waiting to be installed
the numbers where on a stock stall track times coming friday hopefully with street tires
Old Jul 26, 2005 | 07:41 PM
ReedyCreekRacin's Avatar
ill let you know, haha. ive got the 220/224 Comp on the way. getting a tune at the same time. i may not have a chance to put it in this weekend, hopefully next weekend itll be in there. mine's a 5.3, 3.42 gear and a stock converter (for now). CHIP
Old Jul 27, 2005 | 12:22 PM
Can't wait to here how it goes. BTW, sick car you have there.
Old Jul 27, 2005 | 12:31 PM
BLACKND's Avatar
I don't think you'll be real impressed with it on the stock converter. Just my 2 cents. But the power will bog down low and then come in strong in the upper rpms.
