HELP!!! BOGS & HESITATES!!!
Old Dec 30, 2005 | 11:22 AM
ktmrider's Avatar
Sounds like the tube for the PCV.
A leak in any of the tubes coming off the intake would cause your problems. Good catch!
Old Dec 30, 2005 | 12:50 PM
Black Nali's Avatar
Sounds like it is the breather tube that is run from the Purge valve selenoid. The purge valve is located at the front top of the intake manifold, directly behind the T/B. I just had the same problem - like $25.00 from the dealer. It is letting unmetered air into the intake. This will cause it to run lean, along with other problems. Good catch, it took me a month and 2 trips to the dealer before I finally figured it out myself.
Old Dec 30, 2005 | 02:11 PM
LS1TRUCKGUY's Avatar
Is The Valve Or The Tube Around $25? Where Does That Tube Lead To On The Back Of The Motor, I Was Kinda Lookin Last Night, But I Was Limited On Light, So I Really Couldnt Tell
Old Jan 2, 2006 | 10:12 AM
Black Nali's Avatar
I ended up replacing both. The Valve was like $28.00 and the tube was $25.00. Good luck bro.
Old Jan 2, 2006 | 10:21 AM
Black Nali's Avatar
Sorry I didn't read all of your post. The tube leads to another valve port at the rear of the engine just behind the driver side valve cover and fuel rail. You gotta really climb up in the engine to get to it. Can't reach it from below on my truck, you might be able to though. The connection in the rear is just like the slip fit of the front connector from the tube to the valve. Get it on the tube and then squeeze the ring so it will slide the washer over and connect all the way. It's kinda a pain in the ***, and be careful to be sure you get it locked all the way down in the rear or you will have the same problem again (leaking unmetered air). I hope that made any sence to you at all.
Old Jan 2, 2006 | 11:09 PM
cool, thanks, i will try that.
Old Jan 4, 2006 | 11:19 AM
Ok, Heres The Deal. I Have Tried The Starter Fluid Thing Tryin To Find Air Leaks-none. I Cleaned The Maf With Electronics Cleaner-they Were Dirty & Oily, I Guess Filter Oil. I Took The Throttlebdoy Off And Checkd The Plunger In The Top. I Replaced That Tube & Valve That Were Cracked. Now, It Only Bogs & Hesitates In Cool Weather @ 55-60 Degrees With High Humidity, Ideal Conditions Are When It Is Foggy. runs great when theres no humidity.Think Its The Maf? i am gonna try and swap my buddies MAF and see if thats the problem.
kainzien
Nov 10, 2023 11:37 AM
kalikid06
20
Oct 13, 2015 07:37 AM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
lo&sloSierra
Jul 19, 2015 04:21 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
