Help with body control moduel please.
One thing Chevy did not change on the 2003 models is the location of the bcm. It is under the steering column. Remove the knee panel under the column and there you go.
More like what doesn't it control. Basically everything electronic inside the cab, along with outside lights. They cause alot of weird electrical problems too (I work at a Chevy dealer)
What is involved in changing this out? Would the dealer have to tear apart the dash to get to it? I don't want them to have to take my whole interior apart.
Nope, you can do it but there is a procedure that you will have to do so your pcm will recognize the new bcm and your truck will start. I don't have it on me right now but it takes about an hour to synch the bcm to the pcm.
