HELP alterantor
Old Sep 23, 2006 | 01:04 AM
all grounds seem to be fine
Old Sep 25, 2006 | 12:28 PM
bumpity
Old Sep 25, 2006 | 12:35 PM
Tootall's Avatar
did you check the ground strap to the body, and to the frame? Check the contacks on the battery.
Old Sep 25, 2006 | 01:38 PM
Nick™'s Avatar
re-check your grounds.... run ALL grounds to the iron block, not the aluminum heads
I know you are getting tired of hearing "Ground", but these motors seem to be very sensitve to this.
Old Sep 25, 2006 | 02:04 PM
RoninsDenali's Avatar
I had a Funky ground on the block after reinstalling motor/trans. It was so screwy, even my headlights we're acting up. (acting like they were shorted, unplug the bulbs engine wouldnt start lol)
Old Sep 25, 2006 | 04:42 PM
so it must be the ground thats attachted to the drivers side head thats causing this, how the hell can I put it to the iron block now? without ripping everything off?
Old Sep 25, 2006 | 05:07 PM
Removing the intake obviously would give you a lot of extra work room. However, perhaps easier you can unbolt the transmission mount, and carefully with a jack push the transmission up. (tilting the engine forward) giving you a bit more handroom.
Old Sep 25, 2006 | 06:49 PM
looks like ill pull the intake I guess
Bill Reid
Feb 4, 2008 10:18 AM
chris99gmc
Dec 18, 2004 05:03 PM
