HELP...8.1 Loosing Coolant!!!
Old Mar 15, 2009 | 09:51 PM
  #21
BuyAmericanIron's Avatar
Sorry to give poor advise on the intake. The last big block I worked on did have coolant in the intake. Yes, it has been a few years. One last thought, you can always pull an oil sample and send it in for testing. It will show you in PPM (parts per million) how much coolant, if any is in your oil sample. Though not usually done on gas powered engines, it will give you a wealth of information on the internal condition of your engine. Good luck with your truck.
Old Mar 15, 2009 | 10:12 PM
  #22
budhayes3's Avatar
PT's Slowest Truck
Same here
Old Mar 16, 2009 | 09:54 PM
  #23
labmousedb's Avatar
I would look very close at the water pump. just changed Mine at 83K miles, will leak on the belts and sling around under the hood. some times only leak when cold/overnight with no pressure on system.
good luck
Old Mar 16, 2009 | 11:12 PM
  #24
Ender06's Avatar
i will check all this, it has been raining here for a week, dangit
Old Mar 16, 2009 | 11:18 PM
  #25
Jeteys5.3's Avatar
Ender, i know F this damn rain. I can hear it pouring out now...you better find/fix that coolant problem so that turbo can get awhistling hahaha. not even my damn truck and im like excited to see it after its done....haha a big *** 8.1 turbo'd
Old Mar 16, 2009 | 11:53 PM
  #26
Ender06's Avatar
I have worked om it ever f-ing day. I even mocked it up last week. Only a few more things left!!
Old Mar 18, 2009 | 06:41 PM
  #27
Ender06's Avatar
Well guys, it was a nice day today, walked out after work, saw a decent sized puddle under the truck. Got to lookin, and it is the water pump. Dang, but it could be ALOT worse. This sucks right now, cause im BROKE.
Old Mar 18, 2009 | 09:03 PM
  #28
James B.'s Avatar
The water pump is about the most inexpensive component that could have failed causing the problem. I'd say you're in good shape. They're cheap.
Old Mar 18, 2009 | 09:53 PM
  #29
budhayes3's Avatar
PT's Slowest Truck
Werd, straight forward repair too...
Old Mar 18, 2018 | 12:10 PM
  #30
TonyT's Avatar
Registered User
I've seen one Gen-VI and one Gen-VII bigblock leak coolant from headbolts. Both of them were leaking from the short bolts externally visible at the bottom of the head under the exhaust manifold.
I haven't had the problem with mine despite "abuse" (5000+ shiftpoints on stock valvetrain, etc...)
Dex-Cool has a very distinct smell. If you're familiar with the smell you're looking for it's possible to pick it up standing next to the truck without the hood even open in very small concentrations.
For your oil change - I might suggest that you drain the oil into clear juice jugs. Let it stand for a few days and any water in the oil will begin to settle out. Another sign, as you're pouring the oil, is the appearance of lighter strands or streaks in the oil. Oil mixed with water or coolant looks more like chocolate than soy sauce.
James, I have the leak from the bottom of exhaust manifold as you say here and am curious if your findings and next steps. I sent you a PM, thanks
madmann26
Apr 29, 2020 09:17 AM
6.0l RST
Nov 23, 2015 11:30 AM
bearden86
26
Nov 15, 2015 03:58 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
