Thoughts on comps 220/224-.530/.534 in stock lm7?
Old 03-20-2018, 11:22 PM
'01-B4C's Avatar
Default Thoughts on comps 220/224-.530/.534 in stock lm7?
So, I got a deal on this cam for my 5.3 swap. Now I'm second guessing it. what are you guys thoughts? Swap is a 82 c-10 with long tubes and I was planning a stall for the built 700r4 vbut now I'm thinking I may have too much cam after comparing it to the BTR truck cams. ?.??
Old 03-21-2018, 04:57 AM
madmann26's Avatar
It'll work fine. Especially if you run a 2800 stall or so.
Are there better cams? Probably. If you got this one on a deal I'd say run it.
Old 03-21-2018, 07:59 AM
Tayj6's Avatar
That’s more duration than I would have spec’d, but the lift is pretty low. I agree with madmann’s stall recommendation to make it work.
Old 03-21-2018, 08:01 AM
'01-B4C's Avatar
Cool, thanks. As to better cams.....what would you suggest? I may put it up for sale and go shopping.
Old 03-21-2018, 08:15 AM
03sierraslt's Avatar
What lsa is it? 112 or 114
Old 03-21-2018, 08:39 AM
Tayj6's Avatar
I’m a big fan of the cam motion truck cams. I don’t know how much power your trying to make and what you want out of the build.
I like streetable cams with a ton of real world rpm power...but I’m getting old.
Is is this a DD project? Street driver? Street/Strip?
Old 03-21-2018, 09:04 AM
'01-B4C's Avatar
I ran a yank ss3600 behind a stock ls6 in my sons Camaro and loved it, so I was thinking of goin with something similar in this truck. Probably a little less stall for the truck though.
Old 03-21-2018, 09:07 AM
'01-B4C's Avatar
It's a 112LSA and the truck is just a toy. Probably just gonna drive whenever I get the urge. Not going to be something that I rely on for every day use. I have other vehicles for DD.
Old 03-21-2018, 09:50 AM
madmann26's Avatar
Hell, if that's all it is, run a TBSS stall. They're cheap.
Old 03-21-2018, 09:55 AM
'01-B4C's Avatar
Thanks, I'll check out the stock TBSS stall.
Quick Reply: Thoughts on comps 220/224-.530/.534 in stock lm7?
