help on a 5.3lL engine build
Old Jun 13, 2017 | 12:07 AM
FoDo05GMC5.3's Avatar
Registered User
Default help on a 5.3lL engine build
Hello to everyone just looking for some good advice on how I should go about my 5.3l engine build. I have pre existing issues with the motor which lead me to replacing head gaskets so I figured if I have the heads off I want to upgrade cam for some more power and lifters are noisy so I need to know whats a good fix for that. also push rods ive been seeing that those are good to replace while having all that torn down. I personally haven't torn down an engine to the block so all advice is much appreciated
Old Jun 13, 2017 | 07:13 AM
Choda's Avatar
check out my build thread, search for my user name.
Old Jun 13, 2017 | 11:15 PM
01SilveradoJakee's Avatar
Depends on what you are putting the motor in. But if you are going to tear into the bottom end then there are a couple of easy mods you can do for more power.
I just had my heads off my 5.3L and did a cam Lifters Oil pump pushrods sprocket, timing gear, chain Lifter guides, Cam rocker arms valve springs and home ported heads.
Old Jun 15, 2017 | 10:27 AM
FrankensteinE.D.'s Avatar
Banned
FoDo05GMC5.3,
Welcome to the site man! I'd love to help you with your build. What are your goals for the truck and do you have a budget in mind? The link below is a great friend of mine who bought my old crew cab and we worked a heads cam deal into. He drove the truck the day we finished tuning from Fort Worth, TX to Cincinnati, OH. He swears up and down he's getting 17/18 MPGS.
The truck has a reworked factory stall, 243 stage 1 ported heads and a custom truck cam. Sounds great and from what he tells me hurts a lot of feelings. Truck only has 3.08 gears and runs on 32" A/T's with some very heavy BMF wheels with a leveling kit. We had to delete DOD/AFM in his truck. Your build takes quite a bit less to swap. If you have any questions at all, fire away!
-Russ
