help with 4.8l to 5.3l
Old Dec 29, 2007 | 10:27 AM
HAFNHAF's Avatar
Question help with 4.8l to 5.3l
i have been readin the bloggs about the 4.8 and the 5.3l engine bein the same just a different stroke .... so what do i need to do to change the 4.8l to a 5.3L
Old Dec 29, 2007 | 11:43 AM
joshua022's Avatar
I believe all you would need, would be the crank and rods.
You could re-use the 4.8's flat top pistons and get a bit more compresion out of your 5.3.
Old Dec 31, 2007 | 11:17 AM
HAFNHAF's Avatar
so do i need to do any machine work or boaring of any type
Old Dec 31, 2007 | 11:38 AM
thunder550's Avatar
High on diesel fumes
To do it right you'd need new main and rod bearings and new rings, then have the block honed. Since you have to disassemble the block to have the machinework done, you'd also need new head bolts and a full set of gaskets. Bore is the same. Probably not worth the money to convert one to another. You should be able to pick up a good running 5.3 long block for less than you'd spend to convert the 4.8 to a 5.3.
Old Dec 31, 2007 | 12:01 PM
BlownChevy's Avatar
blownerator
25 Year Member
Or just bypass it all and make your 4.8 a 5.7L.
Old Dec 31, 2007 | 08:13 PM
barley's Avatar
+1 thats what I'm working on. It's gonna be sweet.
Old Jan 2, 2008 | 11:06 PM
silveradol33's Avatar
i think the 5.7 from a 4.8/5.3 would be bad ***!
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
