Help with 2010 4.8 build
Old Dec 17, 2011 | 07:54 AM
Gus 82's Avatar
Default Help with 2010 4.8 build
Hello I'm new to the forum but have been in the car game for a little while. I have some questions and hoping to get some answers that will result in the best power for my money. I'm working with a 2010 4.8 Silverado 4x4. I currently have a KNN cold air, Flowmaster drop in muffler on factory piping and a PCMforless tune which is already set up for Long tubes. My questions follow.
I would like to purchase a set of longtubes but need to have cats available due to local emissions check. Our area does not look for California standards but must pass a physical inspection. I have been thinking about the Ceramic Pacesetters and welding in a Magnaflow universal cat to the Pacesetter Y pipe. Any reviews of fitment in this type of setup? Trying to avoid the 1200 Kooks or other high dollar setups.
Next on the list I have been thinking a lot about a cam and wanted to get some recommendations for the above setup. The engine doesn't need to have rough idle since I use my truck to pull a boat and a car hauler I need my brakes. Most of the time sounding fast and being fast are 2 different things unless you got the $ to do it right. Can anyone confirm that the 2010 is a single bolt design and not A 3 bolt. I am looking for a cam that will give lots of Mid range power where I'm going to use it. I am not looking for a cam that is at 5000+ RPM before it starts to really pull since I do not plan on changing the torque converter out.
Due to the power increase from above do you suggest swapping out the servos in the transmission or is this a unnecessary modification? My truck has the 4 speed and if this is something I should look into is there a specific part number I should be looking into?
Finally the tune currently in my truck was done via HP tuners and I do have access to one of these units now and prefer not to pay for the new cam tune so I wasn't sure if anyone could share a tune for the upgraded cam?
I know this was a bit long for a first post but I rather ask then waste money.
Old Dec 17, 2011 | 08:48 AM
6789olds's Avatar
with a 4.8 and towing , gearing will be your best friend. if u are not lifted 4.10-4.30 would be a good . vette servo is also a good mod for towing. then install those lt headers .
Old Dec 17, 2011 | 11:58 AM
Gus 82's Avatar
Gears are on my other list with my leveling kit and a 33 I think I'm in ago with 456. This isn't my daily driver and I usually take out about once a week so it's not a gas mileage concern
luis_bullz
Sep 8, 2015 03:08 AM
USMCvet0311
Aug 14, 2015 10:28 PM
abey15
Jul 13, 2015 02:20 PM
Moto733
Jul 12, 2015 10:25 PM
Cowboy17
Jul 9, 2015 08:22 PM
