Help!
Old Feb 17, 2004 | 08:33 PM
pirate3's Avatar
Default Help!
I did a "basic" port/polish job on my tb and after putting it back together I get a check engine light and a "reduced engine power" signal on my info display on the dash. I have ported/polished around 50 tb's on f-bodys with no problems. Anyone have a suggestion? It's on an 04 SS silverado.
Old Feb 17, 2004 | 08:50 PM
Check the wires to the throttlebody and the TPS.That's what warning you get when you're throttle by wire is messing up.
Old Feb 17, 2004 | 08:52 PM
pirate3's Avatar
Cool, I'll check that. BTW. What's the best way to reset the PCM on these trucks?
Old Feb 17, 2004 | 09:29 PM
Texas Terminator's Avatar
11 Second Club
key on-remove PCM fuses in the fuse box under the hood(two i believe)-wait about 10 minutes-key off-reinstall the fuses
or find someone with a scan tool.
Old Feb 17, 2004 | 09:37 PM
FILE's Avatar
That would be PCM B and PCM I
Old Feb 17, 2004 | 11:25 PM
JSmith's Avatar
Don't the new fly by wire truck TB's have that "tongue" looking thing in them behind the butterfly? The electric TB's don't have a hole in the butterfly so the computer opens the blade slightly and that "tongue" is there to help the air flow at idle. I remember reading here that someone did a port and polish job and removed that and it gave them the same problem.
Old Feb 18, 2004 | 12:32 AM
BlownChevy's Avatar
blownerator
25 Year Member
Yeah he had the SAME problem...maybe he will post here.
Old Feb 18, 2004 | 06:13 AM
2003blue5.7's Avatar
I had a stock one opened up to 80mm "new plate and all" and I got the same code.
Old Feb 18, 2004 | 09:23 AM
pirate3's Avatar
Wel I let it sit overnight with the battery unhooked. I pulled the tb off, doublechecked everything , reassembled and it runs fine. In fact, it runs a bit better now with the ported/polished tb and coolant bypass. Thanks for all the help.
