heads question
Old Feb 14, 2009 | 12:22 PM
06ecsb4.8's Avatar
sorry about the threads.
i have not ported anything yet. I plan on buying an extra set of heads LQ's if possible
and having them cnc ported by a local shop. and changing springs to not worry about it anymore.
so about 11 to 1 should be a safe limit?
i do not plan on installing heads until I have a custom tune for the heads.
will my rpm's be affected? like redline being lower?
Old Feb 14, 2009 | 01:37 PM
95 bright teal's Avatar
I dont believe its possible to get 11to1 on a set of 317's or 243's, especially if they are ported.
I would look for some 5.3 heads and have those milled and ported to give you better flow and higher compression
Old Feb 14, 2009 | 01:42 PM
06ecsb4.8's Avatar
alright. Well thanks for the help.
off topic question
in camshafts whats the difference from 112 lsa to 116 lsa
other than idle.
Old Feb 14, 2009 | 01:43 PM
Wilde Racing's Avatar
How do I change this text
valve event overlap
Old Feb 14, 2009 | 01:48 PM
06ecsb4.8's Avatar
so which is better for n/a higher or lower lsa?
does it move powerband up or down?
Old Feb 14, 2009 | 01:50 PM
typically a narrower lsa will be more "peaky", and a wider will be more broad
Old Feb 14, 2009 | 01:51 PM
06ecsb4.8's Avatar
ok. got it.
thanks
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
