heads to lower compression??
Old May 4, 2005 | 10:36 PM
Default heads to lower compression??
Should I change out my heads to lower compression so I can run more boost on my LQ9
Or would it be a waste of time and money?
Old May 4, 2005 | 11:33 PM
TURBO8's Avatar
I would if I where you. I'm a boost junky. Got to have boost. Lots and lots of boost. J/k I have a set of lq4 heads that will do the trick. 317# casting, they are just sitting in my garage. $350 plus shipping. I just thought I'd throw that in there. smile.
Old May 4, 2005 | 11:36 PM
what will the compression go down to?
Old May 4, 2005 | 11:42 PM
Yelo's Avatar
j4nash...you already have the 317 casting heads on your motor (lq4 and lq9 use the same head), to drop compression on your motor you'll either have to get heads with custom-cut chambers or stack head gaskets (NOT recommended) as the 317 casting already has the largest chamber of all LSx production heads (71cc)
PappyDan's Avatar
Tribe Shaman
nothing, the heads for the LQ4 and the LQ9 have the same cc chamber.
you need the dish pistons from the LQ4 to swap out the flat tops of the LQ9 to get a ratio of 9:48 to 1
Old May 4, 2005 | 11:47 PM
so without getting dished pistons or a custom set of heads there really is nothing i can do?
Old May 4, 2005 | 11:55 PM
Yelo's Avatar
pretty much
I've seen f-body guys run 12-14 psi with proper tuning on 10.2:1 motors...you just have to be conservative with the timing to prevent detonation
GrooveCityZ71
Aug 31, 2015 12:05 PM
steves86ta
Jul 28, 2015 10:21 AM
signguy62
Jul 27, 2015 03:42 PM
Aboss
Jul 9, 2015 10:28 AM
