heads to lower compression??
I would if I where you. I'm a boost junky. Got to have boost. Lots and lots of boost. J/k I have a set of lq4 heads that will do the trick. 317# casting, they are just sitting in my garage. $350 plus shipping. I just thought I'd throw that in there. smile.
j4nash...you already have the 317 casting heads on your motor (lq4 and lq9 use the same head), to drop compression on your motor you'll either have to get heads with custom-cut chambers or stack head gaskets (NOT recommended) as the 317 casting already has the largest chamber of all LSx production heads (71cc)
Originally Posted by j4nash
so without getting dished pistons or a custom set of heads there really is nothing i can do?
I've seen f-body guys run 12-14 psi with proper tuning on 10.2:1 motors...you just have to be conservative with the timing to prevent detonation
GrooveCityZ71
Aug 31, 2015 12:05 PM
signguy62
Jul 27, 2015 03:42 PM
