Heads/Cam going in....it's an unusual combo so I've got a few questions
Old Dec 3, 2004 | 01:44 PM
  #31
Yelo's Avatar
Originally Posted by BigTex
Stock pushrod is 7.38" long. the base circle is smaller on the new cam I'd imagine, so a slightly longer 7.40" pushrod would be fine. I'm running 7.4s with my comp XE .563 lift cam.
Now y'all have got me seriously confused.........
Old Dec 3, 2004 | 01:50 PM
  #32
marc_w's Avatar
Sorry, yeah, 7.38 sounds right for stock.
Old Dec 3, 2004 | 01:55 PM
  #33
Yelo's Avatar
OK, so....my parts list should look something like this:
1. ARP #234-4119 Head Studs
2. Comp Cams #7639-16 7.40" hardened pushrods
3. GM MLS 6.0 Head Gaskets (what about Fel-Pro 4.135" bore .041" thick LS1 gaskets ??)
4. Stock Rockers
5. Stock Lifters
Old Dec 3, 2004 | 01:56 PM
  #34
BigTex's Avatar
Forget everything. Just buy 7.4" hardened pushrods and you'll be fine. They are .02" longer than stock, but thats perfectly acceptable.
Old Dec 3, 2004 | 02:08 PM
  #35
BigTex's Avatar
With that felpro #1041 gasket, you'll increase your CR by about .2 of a point and have a better quench. I've got an extra set if you need some.
Old Dec 3, 2004 | 02:32 PM
  #36
Flyer's Avatar
What he said ... I didn't realize the base circle on that cam was that small. I figured it was like the CC cams. I guess that's what I get for assuming.
Are those FelPro's your talking about graphite or MLS? What's the bore size on them?
  #37
Yelo's Avatar
PM sent
Old Dec 3, 2004 | 02:42 PM
  #38
BigTex's Avatar
replied.
The felpros have a 4.1" bore, but are only like .041 thick compared to the stock .055-.060 gaskets.
Old Dec 3, 2004 | 02:48 PM
  #39
Flyer's Avatar
MLS or graphite??
Old Dec 3, 2004 | 06:40 PM
  #40
Yelo's Avatar
Originally Posted by Flyer
MLS or graphite??
Neither.....
Originally Posted by Summit Racing
Fel-Pro performance head gaskets feature a PermaTorque/blue gasket body with a solid-steel core to minimize torque loss and gasket blowout. They also have a wire-ring combustion seat with stainless steel "armor" for extra sealing force around combustion chambers. They're made with a pre-flattened steel-wire ring, so they have the strength of steel-wire sealing, and the minimum brinelling of aluminum heads.
