Which Headers for towing?
Old 06-25-2006, 11:52 AM
  #51
02RedHawk's Avatar
Originally Posted by litreddevil
i do was told the my compression the big u can put the tubes.
What?
Old 06-26-2006, 09:48 AM
  #52
rgvsierra's Avatar
Originally Posted by 02RedHawk
There's no such thing as "choking" it with a 2.5" collector / Y-pipe. Dual 2.5" pipes flow sufficiently to support over 500hp. So, unless you're making some serious HP, 3" collector/Y is overkill - and actually can reduce your exhaust velocity....
so the pacesetter package, lt/ory is overkill for a bolton 5.3? what is serious hp in your terms?
Old 06-26-2006, 04:01 PM
  #53
02RedHawk's Avatar
...Over 500hp at the flywheel, and even then you'll likely have other restrictions that will be greater than the 2.5" pipes.
Old 06-26-2006, 04:54 PM
  #54
Yelo's Avatar
I've put 600+hp through 2.5" collectors....a 5.3 will have NO PROBLEM breathing through them
Old 06-26-2006, 10:01 PM
  #55
Moddoo's Avatar
EDIT:
started 5.3 thread
Old 01-07-2015, 11:40 PM
  #56
the450r's Avatar
Very good info. I am looking at possibly doing headers and long tubes seem to be the way to go.
I have a 2007 k2500 classic. Lq4, CAI, nbss intake, 87mm tb, x link, electric fans, basic tune, hi flow muffler to duals. nv4500, 4.11 gears and 305/70/16s. DD and tow rig 24' camper.
I think headers will help it breathe better. I was worried about the drop in back pressure from long tubes/ cat delete.
I just installed the intake and am impressed with the gains so far without tune on stock injectors. Do you think after the header install I'll need bigger injectors? Usually the camping trips involve traveling through Colorado. I think 243 heads and a cam swap would be good mods too. not to that point yet.
Oobray
06-13-2022 03:38 AM
Bluecollar Hotrods
03-13-2017 05:02 PM
lsxperformance
04-20-2016 12:17 AM
2500ZL1
01-25-2016 06:30 AM
LARRY01Z28
08-01-2015 10:15 PM
Quick Reply: Which Headers for towing?
