headers, s.c , dtc codes fixes ?
Old Jan 12, 2004 | 03:16 AM
HAZE's Avatar
Default headers, s.c , dtc codes fixes ?
trucks setting ses due to dtc p0131 & 0151. due to s.c and headers any fixes ?
Old Jan 12, 2004 | 10:42 AM
Black Blown 02's Avatar
Those codes are low voltage on both pre converter sensors. Do you have any exhaust leaks? Are the o2's in tight?
Old Jan 12, 2004 | 01:45 PM
HAZE's Avatar
no noticeable leaks, will check more thoroughly today. believe it is due to not being hot enough. cold o2 sensor = low voltage, correct ? i see you're wide open in the exhaust, you've never seen this code ? will run efi log for first time today maybe that will shed some light on it.
Old Jan 12, 2004 | 01:52 PM
No, never set these, but I'm having trouble with a similar code-b1s1 insufficient switching. I switched it to the other side and got b2s1 insufficient switching. So I think ive just got a bad sensor.
Maybe try switching the sensors left to right and see if the code moves to the other side.
Old Jan 12, 2004 | 02:12 PM
HAZE's Avatar
one code is left one right, they are simultaniously setting ses. leads me to believe it is not o2 failure related, rather the o2's are not staying hot enough, to much airflow. sound right ?
Old Jan 12, 2004 | 02:29 PM
Sorry, shoulda read the post more closely.
What kind of headers are they? Are they coated to keep the heat in? I would think that with the heater in the o2 they would stay hot enough though.
Seems like theres alot of guys that get these codes after a header install.I've never seen a solution though.
Flyer's Avatar
What kind of headers do you have? I had that problem with my TOG's before they were coated. It's one of those things you will just have to live with or turn the code off with EDIT. If it's the same thing as I was getting, you are running a bit rich too.
Old Jan 12, 2004 | 08:29 PM
HAZE's Avatar
they are edelbrock shorties, ceramic coated in and out. got ses with s.c before headers but it would always clear itself, now it stays lit. maybe since the headers at higher boost/airflow the whipple injectors aren't compensating enough, causing a lean condition. i'm going out to log with efi live now, see what i come up with. didn't think of that before because the whipple dummy [lean] light has never lit other than during the start up self check. thanks for responding guys i'll give more info when i decipher the efi log.
GM1697
Sep 2, 2015 08:32 AM
chevyl33
Aug 24, 2015 08:21 AM
1bdbrd
Aug 23, 2015 03:24 PM
rudvirus
Jul 15, 2015 09:31 AM
Suburban2500
Jul 13, 2015 09:57 AM
