headers for a lowered 4wd 02 avalanche
Old Nov 20, 2007 | 07:03 PM
Snow Dog's Avatar
Default headers for a lowered 4wd 02 avalanche
I know this has been covered before and I'm sorry if it was recent. I am new to trucks when it really comes to knowing the ins and outs, especially with a 4WD. I need long tube headers and a catted ypipe for an 02 5.3L 4WD avalanche. Truck is lowered 2in front 3in rear. I see some of you with the early trucks have SW long tubes and cats even though that say it's for 03 and up trucks. Think I can use them with this application? What about the Dynatechs?
If I have everything in my mind correct, lowering the truck will actually raise the front axle and drive shaft. So if the y pipe goes under the drive shaft, then I'll have more room since the truck is lowered.
Any other options? Thanks guys.
Old Nov 20, 2007 | 10:06 PM
WJ MARK's Avatar
Im thinking you will probably be fine.
Old Nov 21, 2007 | 08:34 AM
DrX's Avatar
DrX
Here's a couple shots of my SW exhaust near the front driveshaft. Crossover point is near the crossmember.
Attached Thumbnails headers for a lowered 4wd 02 avalanche-picture-006.jpg   headers for a lowered 4wd 02 avalanche-picture-013.jpg
Old Nov 21, 2007 | 09:35 PM
silveradol33's Avatar
your drive shaft does not move in an ifs application. I am not aware of any 4ed kit that actually raises the front diff to correct angles, nor do I think you could do it, due to clearance with the oil pan. You should be the same as a stock truck. Any NBS headers and y pipe should work for that application.
maxspeed05V
Nov 11, 2015 04:20 PM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Allgonoshow
Jul 29, 2015 04:21 PM
vmaxpro
Jul 27, 2015 10:45 PM
