Headers Help!!!
Old May 2, 2014 | 12:49 AM
jerry2185's Avatar
Default Headers Help!!!
I bought some long tubes removed the Stock y pipe and when I looked at the headers I noticed some bolt heads missing... Tried to remove the header from the block and SNAP the head of the bolt broke off... My question is can I remove the bolts without pulling the engine??? It's the front pass side, rear pass side and driver rear that are broken off,
Old May 2, 2014 | 06:17 AM
Chevy_King1500's Avatar
either pull the dog house off or pull the engine.
maybe a good time to upgrade cam and heads
how many are broke?
Old May 2, 2014 | 08:33 AM
ZO6Ted's Avatar
Man I hear that happens often.
Old May 2, 2014 | 04:49 PM
jerry2185's Avatar
The passenger 3 total, luckily one of them was just the head of the bolt so I got vice grips and it came off easily but the other two are broken in the head I can get to the one on the pass rear I removed the wheel liner and it's a clear shot but I think I'm going to have to buy a angle drill to try and get the driver rear it's really tight back there
Old May 2, 2014 | 10:57 PM
VegasJ's Avatar
heard this many of times. I was lucky, had none break.
I've heard some try a tack welded nut over the top on the stud and see if that would work it out... if they broke down flush or further I'm at a loss
Old May 2, 2014 | 11:07 PM
shupe's Avatar
This one worked in my '99 5.3 that had the #7 broke before I got anywhere near it. I wasn't talented enough to hold the wrench / nut / while tacing the remaining stud but my buddy was. Ut sure beat pulling the head ..
Old May 2, 2014 | 11:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Don't try drilling it. Use a wire feed to build up the bolts that aren't flush, then weld a nut thru the center to it. Works every time.
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
dirt track racer 81
Sep 21, 2015 06:44 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
