headers are on...
Old Mar 5, 2009 | 08:54 PM
texasbullseye89's Avatar
Default headers are on...
and are f***ing loud...is all i have to say. Im not subject to an emission test, but do have to pass a visual check, which right now with an ORy pipe, I won't do. Ben suggested having a pair of dynomax bullets welded in at the end of the collectors, and that should quiet it down and pass the visual. if i do that though, would it sound bad if i ran a magnaflow race muffler too? just trying to figure out how to go about this.
cliff notes:
headers and y pipe installed, wont pass visual emission check
debating on using dynomax bullets as "cats" and then running a magnaflow race muffler
sounds like what?
Old Mar 5, 2009 | 09:04 PM
GMCtrk's Avatar
That should work okay.
If you knew before hand about the visual you should have looked into OBX headers/y pipe...they come with dummy cats
dug's Avatar
dug
Banned
what headers did you go with? What year truck?
bullets will reduce/remove the rasp. It will make what ever catback you use sound deeper and smoother
Old Mar 5, 2009 | 09:09 PM
pacesetters. 2006 4.8. i knew about the visual and planned on having something put in place, just notsure what im going to go with.
Old Mar 5, 2009 | 09:15 PM
GMCtrk's Avatar
I still don't understand how you'll be able to pass with that smell. The smell without cats is blatantly evident.
Old Mar 5, 2009 | 09:27 PM
dug's Avatar
dug
Banned
when my truck is warm, the smell aint that bad. Its worse during cold startups
Old Mar 5, 2009 | 09:28 PM
dug's Avatar
dug
Banned
hows the fit? Did you go with coated or non-coated? I should get mine in a couple weeks
Old Mar 5, 2009 | 09:46 PM
coated. fits like a glove. i think i posted in a thread you started already..
Old Mar 5, 2009 | 10:05 PM
why not find some old gutted shells, and have someone weld/clamp the shells on over where they would normally be after the headers?
cheap fix, and keep the loudness.
Old Mar 6, 2009 | 08:32 AM
fredkj3's Avatar
pacesetters... ORY... E-cut out and a stock muffler is my setup... i pass emissions and visual.... when you have a stock muffler they dont think about climbin under to look... and i like the way the stock muffler sounds to... quiet.. but a car guy will know something is different when you bring the rpms up..... best of both worlds too.. loud or quiet.......
