Header wrap
Old Sep 6, 2013 | 10:32 AM
BigDaddy0381's Avatar
okay, I guess i'm going to give it a go and see.
Old Sep 6, 2013 | 12:55 PM
Suburbazine's Avatar
Originally Posted by BigDaddy0381
okay, Thanks. if I bought a new set of headers and warped them. I wounder what the life of them would be? 2 years 5 maybe? I'm still 50/50 on doing this.
You can see as little as a few months to as long as a few years depending on the tubing grade and thickness. As long as you run decent warmup cycles you can extend the life of the tubing significantly- the problem with wrapping is you will absorb moisture and this moisture does a number on the metal if you don't evaporate it with heat. Just warming it up and not getting the moisture out (like short trips to the store) will advance the corrosive process.
Old Sep 7, 2013 | 11:00 AM
PoweredByWinchester's Avatar
^^This^^. Wrapping headers will destroy them prematurely....especially painted headers. Best thing I've seen to reduce under-hood temps is the ceramic coatings from Jet Hot, etc.
The machine shop I use installed a dyno a few years ago. He told me that one of the biggest differences he noticed inside the dyno room was when they started using ceramic coated headers during sessions. Said the temperature in the room was dramatically lower than it was before when they used painted headers.
wretched73
Oct 28, 2015 09:21 PM
GMCtrk
Oct 20, 2015 06:17 AM
dhorner77
Sep 11, 2015 05:10 PM
11MPG
Sep 8, 2015 04:52 AM
