header question
Old Feb 10, 2008 | 11:59 PM
dimedsbc's Avatar
Default header question
i have a 2006 Sierra RCSB with a 5.3 and was thinking about getting the pacesetter lt's, in the picture is shows where you can mount your two O2's, do they only have two on them or do you have to just do the toor and then get o2 deletes.. also installing the headers do you need a turn afterwards or does it run fine.. one more thing just using the o2s with no cats does it burn the sensors up fast or throw codes right away. thanks....
Old Feb 11, 2008 | 12:07 AM
RandomHero's Avatar
To answer your questions in order
1.)They only have 2 holes
2.) You'll need a tune to delete the CEL
3.) It will run, but a tune will make it run much better
4.)The rear o2s just monitor the function of the cats so it doesn't matter if they wear out faster, just take them out.
Old Feb 11, 2008 | 12:10 AM
dimedsbc's Avatar
thanks for the fast turn
zblee
63
Jun 10, 2023 01:25 PM
2500ZL1
Jan 25, 2016 06:30 AM
Stainless Works
13
Nov 5, 2015 03:31 PM
Martin4_8
Aug 13, 2015 07:31 PM
USMCvet0311
Aug 1, 2015 07:45 AM
