Header hitting
Old Sep 15, 2004 | 05:21 PM
Sport Side's Avatar
Default Header hitting
One of the primary tubes is knicking the steering shaft.
Any ideas, other than denting the header?
Old Sep 15, 2004 | 05:24 PM
greentahoe's Avatar
My Thorley's do the same thing. It freaks people out when I turn the wheel all the way and it makes that loud vibrating clanking sound. Id like to know as well.
Old Sep 15, 2004 | 05:25 PM
KJ
Who's header are you using? I installed a set of Dynatech headers the other day on a Tahoe & everything cleared fine. I have also used JBA shorties and had good luck. Let me know I will try to help any way that I can!!
Old Sep 15, 2004 | 06:10 PM
Sport Side's Avatar
Green, yeah i thought i had KR
KJ, Thorleys.
TTT, I talked with one guy here who had this problem and I've gone and deleted his private message. I forget what he did about his same problem.
Old Sep 15, 2004 | 06:12 PM
ThunderZ28's Avatar
12 Second Club
I had a set of edelbrocks do this to me.
I called edelbrock up, and they replaced it free of charge.
said on some of these trucks, the stearing box is just a hair closer to the motor, so when you romp on it the motor twists, and vibrates on the steering shaft.
Old Sep 15, 2004 | 06:15 PM
Sport Side's Avatar
exactly what is happening Thunder
Old Sep 15, 2004 | 06:17 PM
Sport Side's Avatar
Yep, I have it when I turn the steering wheel also and romp at it. The steering shaft neck looks like a camshaft lobe and knicks the header.
Old Sep 15, 2004 | 06:24 PM
BlownChevy's Avatar
blownerator
25 Year Member
Beat it to fit, and paint it to match!
Who's headers are they??
Old Sep 15, 2004 | 06:26 PM
M.Roberts's Avatar
I went to a junk yard, got a shaft off a wrecked truck, cut out the center section and replaced it with a smaller diameter and longer peice of solid steel that I had made by a buddy that works at a machine shop and welded the ends back together making sure everthing lined up. works like a champ.
Old Sep 15, 2004 | 06:30 PM
Sport Side's Avatar
yes it was you Mr. Roberts that I was discussing this with. Thanks. Whats weird is that it started about a month ago. And I've had the headers for a good 2 1/2 months.
blown. yeah thats what my dad said. " take the hammer to it"
Dough Thorley Headers is what I'm using.
