header and gear ?
Old Aug 25, 2003 | 12:40 PM
RED2K's Avatar
Default header and gear ?
1. Will a set of 4.10s out of a F-body work in my truck? Also what will I need to buy to to install them. What size 10 bolt is our again?
2. What else do I need to buy to install my headers. I was told you can reuse your stock header gaskets. Do I need to buy just a new donut gasket or what? They are JBA so you guys that have them let me know YO. Thanks in advance
Old Aug 25, 2003 | 01:18 PM
FILE's Avatar
Default Re: header and gear ?
No they won't fit. You have a 8.6 but an 8.5 will fit fine. To do the gear swap you will need an installation kit that includes the folowing: pinion bearings, carrier bearings, pinion nut, pinion shims,pinion seal, carrier shims, crush sleeve, gaskets & checking compound. Good luck.
Old Aug 25, 2003 | 01:23 PM
Banned
you can reuse the stock header gaskets or if you need i have a TON of them here Alex just let me know. the donut gasket should be fine too...the fbody rearend is 7.5" i believe and we're 8.5ish...something like that. if you've never setup gears before take it somewhere to get it done cuz you'll ruin the gears if you set it up wrong. hey, shark...are you close to UT pan am?
Old Aug 25, 2003 | 01:27 PM
FILE's Avatar
Yes sir.... I am about 10 minutes away. It was my second home from fall 94 - spring 99.
Old Aug 25, 2003 | 01:41 PM
Banned
a few friends of mine are going there next semester and i might just follow suit if i can figure out a way to make money there....is there a home depot in those parts or close?
Old Aug 25, 2003 | 02:19 PM
FILE's Avatar
There is a home depot in McAllen about 10 minutes away from UTPA. I am sure you can find a way to make money down here. Cost of living is probably the cheapest in the nation.
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
ss454327
Oct 17, 2015 03:43 PM
lawhitediamante
Aug 12, 2015 12:14 PM
Ketis
Jul 23, 2015 12:37 PM
