head work?s need good advice
Old Feb 27, 2006 | 11:16 AM
Default head work?s need good advice
hey guys, im wanting to do some work to the heads on my truck. my goal is to get into the 12's without headwork and do it n/a. but whether i do or not, i still want to do headwork later. so what all do i need to do. i know a good 5 angle valve job and some mild port and polishing, but how much should i get them milled. i am going to have flyer do the tuning for me so he can adjust the timing to compensate for the raised cr from milling. but i just would like to know any other tips that i need to do while i have them worked on. thanks
and this will strictly be for racing, im f*cking addicted!
Old Mar 1, 2006 | 01:13 PM
what nobody has any info?
Old Mar 1, 2006 | 02:55 PM
02sierraz71_5.3's Avatar
Depends on the cam you plan on using as too how much I would mill. If I had to do it again I would of taken the same .050 and then dropped another .010 with a thinner gasket. I would shoot for around 11:1 scr on a cam with around 220 duration and no more than .56x lift, 7.5:1 DCR With full exhaust, CAI, stock intake and tune I would expect 340 rwhp from a 2wd
Old Mar 1, 2006 | 04:41 PM
i will be using the cam in my sig. how much cr can i go until i start running into problems with 93 octane. and will i have any problems with piston to valve clearance when taking .50 off. also what is DCR that you referred to? sorry i dont know all of the lingo.
ARC
57
Feb 21, 2022 10:54 AM
The_W
Oct 28, 2015 09:00 PM
Castro45
24
Jul 31, 2015 07:13 PM
4B11T
Jul 13, 2015 03:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
