head swap questions....tex where are you?
Banned
i know if i run the 6.0 heads as is that my compression will drop quite a bit? the only way to bring compression back up is to mill the heads correct? im sure it is but have to ask to make myself feel better about it.
also, with the 222/226 .569/.571 112 cam i wont have any p/v issues i'm sure with that big ole chamber of the 6.0 head, but what gasket should i run for best results? thanks guys....
Sorry, I'm late. Use the Felpro 1041 LS1 gasket - 4.1 bore and .041 compressed thickness, not the stock replacement gasket. Felpor makes several LS1 gaskets, but the 1041 has about 2cc less gasket volume than the stock thickness gasket.
Even with milled heads, you'll have no issues with P/V clearance.
