Head Question???? Milling some 243's for my 5.3
Old Mar 1, 2009 | 08:55 PM
Exclamation Head Question???? Milling some 243's for my 5.3
I've been thinking of another project. Been looking at getting some 243 heads for my 05 5.3. I have 706 heads on now (stock). I am wanting a little more power. I have a really good tuner. Using HP tuner and a wide band. I am wanting some bigger valves and a little more airflow. I will be putting a TBSS intake and 92mm TB. Are the pistons the same on the 2001 LS6's as my truck. And if my calculations are correct, I would just need to mill the heads .0231 to get the proper Combustion Chamber Volume. That is if the pistons are the same. Or is there a better way of getting some good power with a different set of heads?
Old Mar 2, 2009 | 09:20 AM
white lightning SS's Avatar
IMO I would get a set of L92 heads from GMPP. Those have huge valves and flow better stock than any of the other heads ported. The Vette pistons are flat top yours are dished.
Old Mar 2, 2009 | 09:24 AM
nighthawk08's Avatar
you can't put L92 heads on a 5.3 bore.
Old Mar 2, 2009 | 10:59 AM
Why is that? You can still seal with 4.00 head gaskets on the smaller bore. Is the valve that big that it contacts the cylinder walls?
Old Mar 2, 2009 | 01:10 PM
yes. you need atleast a 4.0" bore to run L92 heads due to valve size.
Old Mar 2, 2009 | 01:48 PM
Thanks, That is good to know.
Old Mar 2, 2009 | 07:37 PM
Which heads would be the best for my application. I am just wanting little power. I know I am not just going to have a lot of power. I wish it was that easy, I am just wanting improvement. Any thoughts???
Old Mar 3, 2009 | 08:09 AM
A set of LS6 patriot heads with the 2.02 intake valves would work well.
Old Mar 3, 2009 | 08:15 PM
jake 03's Avatar
I ran 243's on my 03 5.3 they made a good boost in power.I milled them .040 and that worked out really well.
Old Mar 3, 2009 | 08:16 PM
GMCtrk's Avatar
TSP PRC stage 2.5 5.3's.
