head question
Old Sep 3, 2002 | 04:03 PM
renegade4e's Avatar
14 Second Truck Club
Default head question
i'm looking at some aluminum ls1 heads for the new corvettes and have a few questions. first off...they should fit on the ls1 trucks right? and two, what kind of gains would i be looking at?
Old Sep 3, 2002 | 04:27 PM
really slow truck's Avatar
Default Re: head question
personally, i wouldn't spend the money on ls1 heads. i would just get some work done to your heads. or keep your stock heads and throw in a cam. or long tubes, u still need some of those too! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
<small>[ September 03, 2002, 04:27 PM: Message edited by: really slow truck ]</small>
Old Sep 3, 2002 | 07:45 PM
GREGGO's Avatar
Stock for stock, our heads flow better than LS1 heads. I would do some mild P/P and bigger valves and springs. Basically a stage 1 setup with what you have.
Greg
Old Sep 4, 2002 | 07:43 AM
BigTex's Avatar
From what I hear, the truck heads and the LS1 heads have very similar castings. BUT, the truck heads (4.8 and 5.3) have a more restrictive exhaust port. Also the truck head uses 1.89" intake valves. So head to head, the LS1 would flow better than the truck head. The biggest difference is the truck head's chamber is about 59 cc while the LS1's chamber is about 67 cc. That gives the truck head better compression. You see alot of car guys running ported truck heads to take advantage of the higher stock compression.
Bottom line, the LS1 flows better, but has lower compression. There are no gains to be found just bolting them on (unless you have a supercharger!).
Old Sep 4, 2002 | 05:52 PM
red53gmc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fast4.8:
<strong>Stock for stock, our heads flow better than LS1 heads. I would do some mild P/P and bigger valves and springs. Basically a stage 1 setup with what you have.
Greg</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Same thing I heard. The truck heads do flow better than the ls1 heads. Why do you think the ls1 guys put the truck heads on....not to just raise compression, they could mill their own heads for higher compression.
<small>[ September 04, 2002, 05:53 PM: Message edited by: red53gmc ]</small>
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
