Head gasket issues
Old Jul 31, 2019 | 05:19 PM
theonlyChummy's Avatar
Default Head gasket issues
04 5.3 BTR stage 2 truck cam, first a set of 241 heads milled .015 (came on truck when purchased). Drive for a few thousand miles, started pressurizing the cooling system. So I had another set of heads sitting there, swapped those heads, gm head gasket, reused the arp head bolts, drove fine, went and had it re-tuned... made it maybe a week after and popped another. Any suggestions?
Old Jul 31, 2019 | 05:35 PM
madmann26's Avatar
What are you torquing them at?
Old Jul 31, 2019 | 05:44 PM
arthursc2's Avatar
What's timing at?
Old Jul 31, 2019 | 05:49 PM
ZO6Ted's Avatar
Has it been overheated in the past? Maybe the deck isn't flat.
Old Aug 1, 2019 | 12:03 AM
1FastBrick's Avatar
Custm2500's Rude Friend
The Blocks aren't truly flat from the factory. Your's is likely out of spec.
Old Aug 1, 2019 | 04:35 AM
Torqued to 75 per ARP instructions
I couldn’t say if it has or not been over heated in the past. I know since I’ve owned it, it hasn’t been. I caught it before it got too hot.
Timing is at 26*
the deck not being flat is what I was thinking... not exactly what I wanna do lol.
Old Aug 2, 2019 | 08:09 PM
1FastBrick's Avatar
Timing is at 26*
I have 1 block in my garage like that and I have done head gaskets on 2 other motors like that.
The one in my garage has a low spot in the middle on one side of the deck. It also has a core shift issue to one side. It was decked on one side and was clean. when they went to the other side, they had to drop the milling head to reach the deck. After they skimed it you could see it had a low spot in the center of the deck.
One of the vehicles I repaired a head gasket on had coolant leaking out in the front between the head and deck. The head gasket was just replaced prior to me doing it and It seemed odd and we just assumed the gasket may have been defective or maybe they didn't have the head surfaced. It wasn't till after tearing into it and checking the block surface in several areas that we discovered some low spots.
Relentless07Silv
May 5, 2014 03:40 PM
99LsSilverado
May 8, 2013 09:57 PM
shakinlm7
Jan 19, 2011 01:28 PM
L-EATER
Jun 1, 2003 10:23 PM
Ryan23silverado
Oct 19, 2002 12:07 AM
