Hydrolocked engine...head gasket??
Old Oct 18, 2002 | 01:45 AM
Ryan23silverado's Avatar
Default Hydrolocked engine...head gasket??
Hey guys, it's not an LS1 but same principles apply and you guys are smart. The engine is a brand new ZZ4 Chevy 350 ci. crate motor. We fired it for a couple of minutes, then it sat for 6 months. Today I tried starting it again and it locked up. I removed the spark plugs and coolant came out of 7 and 8. (not to mention i bent 3 pushrods trying to crank it initially) There is no coolant in the oil, so it isn't intake related? The only thing I could reason is a cracked head or bad head gasket. Any other ideas? I will pull the heads soon.
Your help is appreciated <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> , Ryan
Old Oct 18, 2002 | 07:42 AM
GREGGO's Avatar
Default Re: Hydrolocked engine...head gasket??
I think your on the right track. Cracked head or bad gasket would be my first guess. How many miles? Did you recheck torque on everything before you fired it up the first time?
Old Oct 19, 2002 | 12:07 AM
It was a new crate engine from GM. It was only fired once at the warehouse and then once again for 3mins. (no miles at all-just idle)
Next time I buy a crate, I think the torque on the heads is something I will definately check. I think the engine builder did not do this correctly.
Even though it isn't under waranty any longer, I received news that the dealership will look at it for me. I know the guy who owns the dealership, so I am hoping.
Thanks for the reply Greg, those were the only things I could think of that would cause this problem also (other than a cracked block, but that is iron...)
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Ryan
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
lxcoupe
Oct 4, 2015 08:07 PM
1989k1500
Sep 29, 2015 10:53 AM
sTNT971
Sep 26, 2015 04:22 PM
