Head choice for a 427
Im building an ls next 427 in an 02 2500hd what would be better for a torquey street motor afr 230s or afr 245 cathedral heads im using a 2400 stall converter
What's your cam spec looking like? And compression ratio?
and why a 2400 stall if you're looking for torque? Going to be soggy right in the middle of all that off idle torque a big motor offers
I'd lean on the 245 initially, but torque is about port velocity, and that's largely dependent on the valve size and cam choice
darkirish63 (06-21-2021)
im trying to keep it around 10:1 due to the bad gas we have in thd boonies here should i have it ground with advance
budnikSS
01-21-2009 11:51 PM
