Having kr problems!
Old Apr 10, 2005 | 04:24 PM
Yellowsierra's Avatar
Default Having kr problems!
I am having some kr problems and am trying to figure it out. It probley just needs fine tuned a little but it was running great about a month or two ago. I wonder if I have a bad injector(42lb.) or my fuel pump(walbro) is acting up. I checked it out today and its pulling 3-4 degrees at low speed and 2-3 degrees up top. I'm pushing 11psi with my whipple but have alky injection. Any thoughts would be appreicated.
thanks
Yellow
Old Apr 10, 2005 | 04:53 PM
It could be the difference in outside air temps,with you running 11lbs.of boost you are probably on the edge with your tuning.
Old Apr 10, 2005 | 08:03 PM
i'm having the same problem and the same setup. I too think it's the tune. I also am still not convinced that the alcohol is doing anything other than messing with my a/f ratio. time for a new dyno tune i guess.
Old Apr 10, 2005 | 08:13 PM
Can you get scanner readings of when this occurs? Sounds like we all have the same problem.
Old Apr 10, 2005 | 08:58 PM
My wot readings are 860-870 mv with about 13 degrees of timing. I drove around tonight and it was pulling up to 8 degrees of kr at normal driving and only 2-3 degrees at wot. I think the readings are false but I could be wrong. I'm thinking of unpluging my knock sensors and just saying the Heck with it. What do you all think.
Old Apr 10, 2005 | 09:54 PM
the 2-3 degrees at WOT might be that 11 PSI is pushing it pretty good. Are you intercooling. Your IAT's will be a big factor. Have you repeated the test with race gas.
Old Apr 10, 2005 | 10:26 PM
All I know is that in January I ran a 12.41 at 8 psi and know I can't even run a 12 run with 11 psi? I guess its just my luck but maybe I will figure it out.
Thanks
Yellow
Old Apr 11, 2005 | 04:02 PM
TigerFan187's Avatar
Probably the heat outside. Im having to put 5-6 gallons of 100 octane AV fuel to keep from Det but you guys are dealing with boost!
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
