Having to change heads due to coolant loss so......
Old May 27, 2013 | 11:34 PM
dust6928's Avatar
Default Having to change heads due to coolant loss so......
I am wanting some advice on heads and cam swap on the low low..... If you didn't see my last thread, I have a coolant loss problem with no visible leak yet I am putting 2-4 quarts a month in. I couldn't find a leak or any signs and took it to a reputable shop in the Memphis area and neither could they. Only thing I have found is number 8 plug is cleaner than the rest. So, I am tired of chasing the issue and am going to change the heads. While at it, I figure I will throw a cam in. Would like a little thump but needs to be every day streetable with minimal extra mods other than tune. Suggestions please!!!
Old May 27, 2013 | 11:46 PM
Chevy_King1500's Avatar
heads: 243's milled .030
cam: 212/218, trucker cam, 220
and some LT's
Old May 28, 2013 | 12:04 AM
Mangled03gmc's Avatar
Baltimore Whore
^^^^ that will work. Also just for *****, once you pull the heads off see if they are the CAST TECH heads. They will have a battery looking logo in the front/back of each head in the rocker arm valleys.
Old May 28, 2013 | 09:59 AM
dust6928's Avatar
Mangled I have the 706 casting heads which from what I have researched were the main castings with issues.
Old May 28, 2013 | 08:55 PM
dust6928's Avatar
Any other suggestions???
Old May 28, 2013 | 09:32 PM
Isak81's Avatar
Stock4.8 sells an Isky Tripple 12 that does pretty well.
The_W
Oct 28, 2015 09:00 PM
thunder550
Oct 8, 2015 04:53 PM
1979rs/z28
Sep 23, 2015 08:39 AM
BIGD4504
Jul 28, 2015 11:46 AM
4B11T
Jul 13, 2015 03:48 PM
