hard 1-2 shift(hd-2 trans-go)
Old Mar 3, 2005 | 07:22 PM
Deckhand's Avatar
do you have a stall? converters usually soften the hit of the shift a little.
Old Mar 3, 2005 | 07:31 PM
Kano's Avatar
Originally Posted by Deckhand
do you have a stall? converters usually soften the hit if the shift a little.
yeah especially at low throttle
theres a certain spot I can hold the gas and never feel a shift
I may be selling mine in about a month or so
I need a touch of pink in my truck
Old Mar 3, 2005 | 07:38 PM
trimmen's Avatar
no stall,i'll talk to the installer seems like he to thought the 1-2 was a little stiff,if i rember right he mentioned going back to the stock servo if i wanted a softer 1-2.so i might do that.thanks gamedawgx53 for your time and info,i'll post results it may be a week or so before i can get it in the shop.take care.
Old Mar 3, 2005 | 07:40 PM
ronn25's Avatar
Ask the shop who did your install how many washers (spacers) they installed in the 2 accumulator. Its easy to remove the pan, and the cover on the accumulator and remove some spacers. You don't have to remove the valve body.
Old Mar 3, 2005 | 08:01 PM
Kano's Avatar
no prob dude
another thing I would reccommend is getting rid of the
plastic 1-2 and forward accumulators
sonnax makes aluminum pinless ones and
gm makes ones out of aluminum with pins
either way plastic is bad
the gm ones will be simpler
I know it sucks going back in
but they will crack or the pins will wallow the
pinhole out and cause a loss in line pressure
slip and burn up the tranny
once it slips hard
Its days are numbered
blownss27
Aug 14, 2020 08:27 AM
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
