Guys w/ true duals inside
Old Aug 20, 2003 | 05:46 PM
01SS's Avatar
Default Guys w/ true duals inside
Ok ive taken my truck to 2 different exhaust shops in town, and neither one would put up true duals. WTF is going on... the last shop said that if they cut the pipes in between the flange and the O2 sensor that they wouldnt be able to get the welder up in there to seal it properly. Did they shops that did your guy's give you any sh@#T? Did they have to drop the whole assembly down off the headers to weld it properly?
Thanks
Chris
Old Aug 20, 2003 | 06:29 PM
Smoky02's Avatar
Default Re: Guys w/ true duals inside
The shop I got mine done at was in Alabama, but they didn't give me any grief...
Old Aug 20, 2003 | 07:11 PM
ThunderZ28's Avatar
12 Second Club
nope they cut the pipe right before they joined and went from there
Old Aug 20, 2003 | 09:49 PM
Flyer's Avatar
Nope .. they worked magic on mine. No grief .. just a bill.
Here are some pics
http://bettie.homeip.net/atvpics/truck/exhaust
Old Aug 20, 2003 | 09:53 PM
one03sierra's Avatar
Formerly one92rs
Old Aug 20, 2003 | 10:04 PM
Banned
i've had three different true dual systems on mine, 2 with stock pipes just cut off before the stock y and made into duals and the latest one is right off the back of the headers, full mandril bent tubes back into an X pipe and out into dual dynomax bullets with a 45* dump before the axle. no problems at all ever to make true duals with/ or without stock pipes.
Old Aug 21, 2003 | 01:13 PM
the exaust shop i had mine done at just cut right before they joined. no problems at all. are you going to remove the cats? if not i see no reason to get rid of the existing pipe.
Old Aug 27, 2003 | 05:59 PM
01SS's Avatar
thanks for the replies. looks like im going with 3" true duals w/ a magnaflow x pipe. Ill post some soundclips soon
Old Aug 27, 2003 | 06:56 PM
GREGGO's Avatar
Here is what I did the last time I messed with one.
Old Setup:
New Setup:
Same location as before:
Old Aug 28, 2003 | 03:42 PM
Heres what mine looks like. . .
