Guys with nitrous,please advise.
Old Apr 11, 2003 | 09:44 PM
03-Z71-5.3's Avatar
Default Guys with nitrous,please advise.
I am planning on a 75 shot to my truck with very basic bolt-ons, do any of you have a favorite kit or somethinig safe and proven.
Old Apr 12, 2003 | 03:21 PM
Hit Man X's Avatar
Default Re: Guys with nitrous,please advise.
Nitrous Oxide Systems makes a kit for the new trucks now. Here's the link....
http://www.holley.com/HiOctn/ProdLin...NOSNS/GM2.html
You will need: the kit, purge, warmer, and a gauge to get the most from this kit. You are looking at about $1000 all said and done.
Spray is great, just use it in moderation depending on your motor.
Old Apr 12, 2003 | 03:40 PM
parish8's Avatar
single digit dreamer
i like the nx set up, it is a wet kit, for the kit with the accesory kit it will run you $800-$900new, that includes the heater. i don't really see the need for a purge unless you like to show the plume of nitrous to the people you are about to race. i just give it a quick shot thru the motor before i race to purge the lines.
these kits come up often used, i got a kit with heater, remote gauge and line, window switch, purge, ........ for $525used
Old Apr 12, 2003 | 03:43 PM
really slow truck's Avatar
yep, there really is no need for a purge valve unless you want to show them you have nitrous. doing as parish says will do the same thing, as well as spraying for a split second during ur burnout
Old Apr 12, 2003 | 04:45 PM
Hit Man X's Avatar
I just don't like to do a purge through the motor, sounds silly as I am about to spray but that's me.
Hell ya, used stuff is the way to go. Most stuff isn't worth nearly what you pay for it so check out ebay, local speed shops, etc
Old Apr 12, 2003 | 10:09 PM
parish8's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Hit Man X:
<strong> I just don't like to do a purge through the motor, sounds silly as I am about to spray but that's me.
Hell ya, used stuff is the way to go. Most stuff isn't worth nearly what you pay for it so check out ebay, local speed shops, etc </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">your not just spraying nitrous, you spray both just like when racing, it doesn't hurt a thing. i usualy rev the motor up above 2000rpm(in neutral) before i bump the button, during the burnout sounds like a good idea too but i don't do a burn out <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> .
i do agree a heater should be considered a requirement at least on a wet kit, most of the time when i crack the bottle the presure is under 800psi, should be over 1000. one cool thing about the nx kit is a powerfull heater with an automatic presure switch, just turn on the heater and forget about it. if i were going with a new kit i would get one of the new nx bottles where you can put the bottle heater switch before the valve, that way you can heat the bottle anytime you 'might' need it without actualy opening it. looks to me like i waste about 1/2lb of nitrous everytime i open the bottle and often i end up not even using it.
Old Apr 12, 2003 | 10:26 PM
BigTex's Avatar
I recently switched to a 15lb. NOS bottle with a build in gauge. Besides holding more, I don't have to open the darn thing to see how much pressure is in it. I also think that I waste a lot of nitrous just by opening it and not using it.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
