Guys with cams
Old May 26, 2006 | 09:33 AM
white1's Avatar
Default Guys with cams
What (on average) is your oil consumption over 3000 miles, and also what are your cam specs?
I have a 223/226 in my 6.0, and usually use 1 qt between changes.
Old May 26, 2006 | 09:41 AM
Nick™'s Avatar
my stock motor has since day one drank about 1 qt between 5,000 mile oil changes, I don't think you have any issues
...and no I won't help you pull the motor, cam, heads or whatever it is you are trying to justify swapping this time
Old May 26, 2006 | 12:26 PM
negativeswitches's Avatar
none since i redid the valve seals when i swapped mine in
but before it was about 1 qt
Old May 26, 2006 | 12:30 PM
dewmanshu's Avatar
Moderately Differentiated
almost a quart in 3000 miles. If I get side tracked and don't chnage my oil with in 5000 I am hurtin. I can almost get a 2 quarts in to the fill line.
ZR1 DREAMING's Avatar
I only have 30k on the clock but haven't lost any with my 223/225 564/571 114 in my LQ9.
Old May 26, 2006 | 12:33 PM
FILE's Avatar
None at 39k miles.
Old May 26, 2006 | 12:35 PM
TIM Z's Avatar
11 sec. Truck Mod
none here either. could it be related to the early Ls1 oil consumption problems?
Old May 26, 2006 | 12:49 PM
bluecajun5.3's Avatar
11 Second Truck Club
none here with 44k
Old May 26, 2006 | 12:56 PM
white1's Avatar
Possibly, my 5.3 never used any, till I changed teh PCV valve, I got another new one when I dropped the 6 in there, and my "check engine oil" light comes on before the change most of the time. Its always 1 qt low when the light comes on.
Old May 26, 2006 | 01:01 PM
Z284thgen's Avatar
11 Second Club
like 1 qt low from full or 1 qt low from the add line
