Gutting cats
Old Jun 20, 2006 | 08:06 PM
MorepowerTY's Avatar
Default Gutting cats
Ok, I've seen alot of threads on gutting cats. Should I buy free flowing cats or gut mine? Never gutted one. Is it easy or do I have to reweld? Will it effect the o2's, and what kind of gains should I expect? And last but not least, will I still past the smog test?
Old Jun 20, 2006 | 08:41 PM
Charged_5.3's Avatar
The only free flowing cats are gutted cats. You should see maybe 5 rwhp. Its pretty easy to gut the cats and no, you shouldn't be able to pass emissions.
Old Jun 20, 2006 | 10:14 PM
NeverSatisfied02's Avatar
You can get o2 Sims for the check engine code set off by the rear o2 sensors. That will take care of that.
Im trying to decide if i want to gut mine and have a pipe welded down the middle inside the cats or if i should just do away with the casing and all and order the Pacesetter Y-pipe when i order my LT's.
Old Jun 20, 2006 | 10:32 PM
Quik's Avatar
5 year bitches!
ditch them and i passed emissions with my truck and no cats and a none stock motor
no SES failure=passing of emssions
Old Jun 20, 2006 | 10:47 PM
Yea i guess thats true! Since they just plug the little monitor thing into your PCM outlet under your dash, if it reads all clear, it passes! I forgot about that. Its only once the vehicle is 7+ years old or something like that where they start putting the little tester in your exhaust pipe to actually test how much smog is coming out.
Old Jun 21, 2006 | 03:21 AM
Quik's Avatar
5 year bitches!
no no, its if it has ODII or ODI detereming how it gets done
Old Jun 21, 2006 | 03:33 AM
TXsilverado's Avatar
in texas 96+ cars are only plugged into the obd port. the guys that inspect my truck knew i didnt have cats or egr and their only concern was if i was throwing codes. i also had to roll down my windows i even did it with the cutout open so i was running straight longtube headers. they didnt give a ****
Old Jun 21, 2006 | 11:41 AM
Dman, where was this at?
Old Jun 21, 2006 | 11:44 AM
blu01slver's Avatar
in florida they dont even test ya anymore... the old building where it used to be done is now abandonded... so if only there wasnt that stupid sensor in the back
Old Jun 21, 2006 | 11:51 AM
EvilChevy's Avatar
go with an ORY becasue gutting cats is not intelligent.. I'd rather have the ORY for my apps but i live in non Emissions county
