gutless 5.3
Old May 29, 2005 | 03:30 PM
Mr. Sandog's Avatar
Originally Posted by Dub Silverado
I thought the z06 cams make high rpm power which would not help in this situation. Gears, some cam, and a stall would really help you out.
Read my post again - this time more carefully. I said LS6, not Z06.
The 02/03 LS6 cam is ideal for power right off idle (600 RPM's) all the way to redline.
Old May 29, 2005 | 07:40 PM
Rhino79's Avatar
9 Second Club
Gears, 4.10's or even 4.56's depending on your tire size. Stall converter...anything above stock will help, and a good tune. Good luck!
Old May 29, 2005 | 07:44 PM
Mr. Sandog's Avatar
Gear replacement in a 4WD is rather expensive. I'd say go for a cam like the LS6 or the one in my sig, and/or a higher stall converter.
Old May 29, 2005 | 07:50 PM
custom 68's Avatar
I thought ls6 and z06 were interchangable names for the same engine? Is this not correct Naked AV?
Dave
Old May 29, 2005 | 08:06 PM
Mr. Sandog's Avatar
Dave
Well, the LS6 is a motor, and the Z06 is a car, so I don't think they are the same thing.
Regardless, the 02/03 LS6 cam is what I am talking about, and the specs on this cam will give his 5.3L what he wants - more *****. Even the '01 would work...it is very similar to my cam.
Behold (scroll down):
Old May 29, 2005 | 08:13 PM
white1's Avatar
werd. 4x4's are expensive on gears. I had a quote or $1200 for the front axle before I did them myself on my 98.
I have a 2000 rcsb Z-71. It feld kinda weak stock, but with just a few mods, (see sig) it really woke it up from a stop. Especially after I replaced the two bad plug wires. And the other 6 too. My truck has a little over 100k miles, and it runs damn strong IMO for a 4x4. I think the LS1 fans or TB port/polish, stop mod helped the most. Besides replacing bad plug wires. I'm ready to replace my muff and take it to the track again.
Old May 30, 2005 | 12:38 AM
rumblebox's Avatar
i was going to mention an 02-04 Z06/LS6 cam, but i was kinda thinking it was a high RPM cam. i had thought about just swapping the gears for 3.73s, but gears dont really fix the no low end torque problem but just cover it up. i'd like to keep my nice highway gears but still not have to downshift every time i want to feel it move. headers and tuning are probably what i'll do
Old May 30, 2005 | 12:41 AM
rumblebox's Avatar
the 01 LS6/Z06 cam was milder than the 02/04 version.
the stock LS2 cam is identical to the 01 LS6 cam.
how do my stock 5.3 lobes compare to these?
Old May 30, 2005 | 12:43 AM
Mr. Sandog's Avatar
You've got an LM7, if that helps you at all.....
Old May 30, 2005 | 12:14 PM
rumblebox's Avatar
i thought it was an LM4. lol so yes it actually does help.
